I have a m35a2 with the original duallies on it. I went to go for a drive, so as always i checked my brake fluid. This time is was empty... So i crawled under and found a puddle of brake fluid under driver side middle tires. I ordered a wheel cylinder and figured id get the truck ready for when it arrives. So i broke torq on the lugnuts and then jacked it up and put it on a block... I went to remove lugnuts the rest of the way and it turns out the shaft itself is turning, not the nut. I thought ok, that will work too, but at some point they all got hard to turn again and dont seem to be coming out any further. I know im an idiot for not knowing how this works, but i stopped and figured id post on here so some one can get a laugh and maybe help while i look through TMs. I didnt want strip or break the posts so ima let it be till i have more info. Ive never had the rear tires off, only the fronts. Do i simply keep cranking? Or is this the wrong way to get the rear tires off?
