Refreshing Gunny the thread.
20,742
1985 Rubber Trans mount versus new Polyurethane trans mount. Seeing this is what made me pull the trigger on redoing all the body mounts.View attachment 874333
Got the Energy Suspension body mount kit in today as well.
I imagine it will make a big difference rolling down the road... The oddball squeaks should disappear too when you get some real rubber between the frame and body. Just replacing the (only) two cab mounts on my M1088 almost made it ride like a Cadillac. Yeah, okay like a Cadillac with four square wheels - but definitely better!
GunnyM1009
530
Roanoke/Alabama
So my kit from Energy Suspension was missing one of the 2-1/2 inch washers. I contacted ES and they would not send me a replacement because I ordered it from Amazon. Amazon issued me a $20 dollar refund to buy the piece since ES wouldn't honor there product. I couldn't find the correct size so I made one.0729220553a.jpg
One washer inside of another and welded. I realize I'm not a welder but they are permanently stuck together.
GunnyM1009
530
Roanoke/Alabama
I'm honestly thinking about cutting up the anti squeak kit and just putting the material on the high parts of the ridges. The factory one that I scraped and sanded off held a lot of dirt and moisture in the valleys being that it was glued all the way across. Any thoughts to the contrary and reasons why would be welcome. Also what adhesive would be best to glue the new anti squeak on?
cucvrus
10,502
Jonestown Pennsylvania
So my kit from Energy Suspension was missing one of the 2-1/2 inch washers. I contacted ES and they would not send me a replacement because I ordered it from Amazon. Amazon issued me a $20 dollar refund to buy the piece since ES wouldn't honor there product. I couldn't find the correct size so I made one.View attachment 874429
You may as well make a gantry and lift the body off the frame.
cucvrus
10,502
I was not talking body off restoration. I was talking getting the body up high enough to gain access to the current rear body mounts. Depending on rusted fasteners that can be a real chore. I use winches on the ceiling and bottle jacks to lift and shift the body around. A ratchet strap helps a lot also. I am doing the Energy Suspension cab/body mounts on my Little Red M1009 project today. I am going to complete this truck this year. I have screwed off long enough.
GunnyM1009
530
Roanoke/Alabama
I got you. I misunderstood, I am replacing them all before the fuel tank, transmission, and transfer case go back in. The fuel tank being out makes getting to the rears easier. I'll have to start watching Little Reds thread a little closer glad you are finally going to get it completed.
cucvrus
10,502
I heard a green grasshopper has a green Hiney hole. I never looked. I used Energy suspension motor mount inserts on every build. For someone to say these CUCV rattle boxes have more vibration is Ludacris. The only time I felt no vibrations on a CUCV was when it was parked and not running. My ears still vibrate a half hour after I get out of one. Ever hear katydids while driving? I do everytime I am in a CUCV. They are good and easy to install.
GunnyM1009
530
Roanoke/Alabama
Appreciate it. I'll go with the Energy Suspension inserts.
GunnyM1009
530
Roanoke/Alabama
Spent the day trying to get the horn working. The old horn did not work so I ordered a new horn and contact kit from LMC. Hooked up the new horn and installed the contact kit and click no blow. Tested the horn with a jumper it works. Cut out the capacitor at the horn and the diode at the relay and click. Pulled out the test light no power at the horn. No power at the bulkhead connector. Power going to the relay but nothing coming out of the wire to the horn. Removed the relay popped the cover off and cleaned the contacts. Put it back together and reinstalled still just clicks. I ordered a new relay I hope that's the issue because that's where the power is stopping.
GunnyM1009
530
Roanoke/Alabama
Got the horn figured out. Turned out to be corroded connections. When I cut the capacitor out in the front my wire wasn't long enough to reach the horn so I splice a piece in between the original terminals. I used a fingernail file to clean up the connections but apparently it wasn't enough. I jumped between the relay terminals as @cucvrus suggested then followed the current out to the connections. I cut those out and put on some blade connectors. Horn works great now. Still don't understand why I wasn't getting my test light to light up when I was probing the power out of the back of the relay. When I pressed the horn it should have lit up. But at least it's working now. One more thing to mark off the list.
