removeing cluch and flywheel
red devils dude
Ft Campbell
I need to pull my tranny to finish rebuilding my engine and sence I have it
all apart I going to rebuild the cluch and have the flywheel turned but I need a good
way to barr the engine to remove the flywheel, if anybody has a idea speak up.
ken
27
Houston Texas
Remove srarter. Have soldier B hold a prybar on the flyweel teeth. Soldier A use a inpact to loosen bolts. Or have Soldier B hold a socket on the bolt in the harmonic balencer. Or reinstall the fan belts As tight as possable. Then put a C-Clamp on the belts aginist the harmonic balencer. Or do all three at once (you may need Soldier C for this) GOOD LUCK!!!
mangus580
283
Western NY
oh... never mind...
RDD... does this mean I have to be soldier B for once? :freaked: I have not yet had to have that honor/disgrace... [^]
ken
27
Houston Texas
Almost forgot. Stick a 2x4 board between the crank and block since you have the oil pan off.
