replacing precups
llong66
kokomo, In
Hello, after help from a fellow member, I sourced a precup for the one I found cracked. I know how to remove the old one, but is there any special way to install the new one? My initial thought would be to simply use a piece of hardwood on the cup and pound it into place. Does this sound correct/good. Any other thoughts ideas?
Thanks much!
Greg
MAZ537
23
EU
I am not sure on these engines but we install new precups in VW AAZ engines with the way you desribe w/o issues.
GG
rustystud
3,389
Woodinville, Washington
Just make sure the bore is totally clean ! We use a round metal bristle brush with lots of brake cleaner or lacquer thinner with an electric drill. Then blow it out with a air nozzle. A little "anti-sieze" is also a good idea.
