Return fuel line Fittings
yolner
68
Rockville, MD
I agree here is what i bought from McMaster when i did mine. I did not use all of it so if your on a tight budget you don't have to order all this.
1. 5097T61825 Ft.D.o.t. Choose-a-color Nylon Tubing For Air, Nonreinforced,.17"id,1/4"od, .040"wall,yellow,25'
2. 5097T66225 Ft.D.o.t. Choose-a-color Nylon Tubing For Air, Reinforced,.251"id, 3/8"od,.062"wall, Yellow, 25'
3. 51835K2811 PackBrass Dot Compression Tube Fit For Nylon Tube, Sleeve For 1/4" Tube Od
4. 51835K2821 PackBrass Dot Compression Tube Fit For Nylon Tube, Sleeve For 3/8" Tube Od
5. 51835K2911 PackBrass Dot Compression Tube Fit For Nylon Tube, Nut For 1/4" Tube Od
6. 51835K2921 PackBrass Dot Compression Tube Fit For Nylon Tube, Nut For 3/8" Tube Od
7. 8359K11325 Ft.High-strength Clear Nylon Tubing, .096" Id, 1/8" Od, .014" Wall Thickness, 25'
8. 50915K2411 PackCopper Tube Support For 1/8" Tube Od
9. 50915K2451 PackStandard Brass Compression Tube Fitting, Tube Support For 3/8" Tube Od
10. 50915K2431 PackStandard Brass Compression Tube Fitting, Tube Support For 1/4" Tube Od
Thanks! I hope you don't mind me making it a bit easier to read.
EDIT: Hah just realized that post is from 2011, but it's still easier to read.
rustystud
3,390
Woodinville, Washington
View attachment Scan.pdfHere is the correct fittings from "Parker" . There called " Hi-Duty Flareless Tube Fittings " . Here's the pages from the catalog describing the fittings. Sorry the description page came in upside down. You will still need the inserts too.
WillWagner
3,164
Monrovia, Ca.
McMaster sells the correct fitting for the line, I posted on this years ago. Somewhere around here I have a bag full of them. I'll dig them up. Although they MIGHT have gone with the truck, but I think I have seen them since, who knows. CRS!
rustystud
3,390
I'm just saying these are the original from my original nonrebuilt engine. I took them to a Hydraulic specialty shop and they matched mine by fittings and number. If the ones by McMaster work, that's fine.
