- 2,960
- 33
- 48
- Tiro, Ohio
I would take that truck in a heartbeat. Drive it to work on oil.
The 302 is a straight-six gasoline engine, used in the 1950-55 M135 series 2.5 ton trucks.as for the 302 im not sure what your referencing
What, no data plates on the dash?Well guys im off tomorrow and will be headed down there. I will get pics of the trans and T case. As for how the engine was installed. the body was lifted off the frame and suspended over the truck. The engine was then set into the frame and hooked up. next the body was modded to fit back in place. the long bed dually bed was replaced with a short bed and a large home made fuel tank installed. the frame is reinforced. All the above was reinforced with grade A american steel. any idea where the trans ID tags normally are?? As for getting her running again i need 2 new batterys and to do a oil change and fuel filters, also clean out the fuel lines and tank, does anyone know where i can get the filters for this thing?? also what about engine oil weight?? Trying to find the right info in the manuals on here are like finding a needle in a hay stack or its just me. Help with that would be awesome
