Reviving the 83 ford with LDS 5 ton drive line
Katahdin
25
Scarborough, ME
nk14zp may be on to something. I think I can make out a fuel cut-off solenoid beside the hydraulic head. Those solenoids were not used on deuces correct? Also, I can only make out one secondary fuel filter, did the xm757s have a third/final filter? The oil cooler also looks different to me...
3dAngus
102
Perry, Ga.
Not sure what it came from, but your Grandfather is MY HERO.
Totally unique and a fantastic job of engineering it in.
Thanks for sharing. Now.... how do I get a Grandpa LIKE THAT!
Kayne
Savannah, Ga
Ok guys i found the ID plates on the Trans and Aux gearbox, Note i thought the Aux Gear box was the T case but its not, Rear Wheel only, But that being said the Trans is a Allison TX200-6, The Aux Box is a Brown Lipe Gear Box made by spicer. The trans from can tell came out of XM757 missile launcher hauler. This was confirmed when i call my G"ma as she said my G'pa pulled it out of a old missile launcher. Now im going to load all the photos i took.
Kayne
Savannah, Ga
heres the The Gear box and the rear end along with the rear end. Also some more of the Dash
Katahdin
25
Scarborough, ME
This just gets better and better!
Calling cranetruck.... Are the fuel filters the same on the xm757 engine? I saw from his posts that the filter canisters are different, top loaded, etc.
Lets help Kayne get this thing runnin! :D
Kayne
Savannah, Ga
I know some of you all wanted to know what trans as u wanted a auto for your deuce. From what i found this is a 6 speed auto with lock up. They were in several different trucks, mainly the XM757. They where 8x8 so i imagine it had a T case on it or a divorced T case. Cranetruck could probably answer that tho. Did find the Full Rebuild and op manual for the TX200-6 on google e books of all places. currently reading through it lol. From what i can see it doesnt just have drive, It has 4 sets of gear ranges it will start in and then allow it to shift through. trying to figure this part out.
tm america
25
merrillville in
Some awsome parts on there.I am looking at this in total disbelief that someone took apart a really rare 8x8 xm757 amphibious truck to put the engine and trans in a f350?wow
flatheadvff
12
Myra/Texas
465dt with auto
I don't know about the military parts. but that is not a 89 Ford in the pictures. The latest it could be is a 86. Ford changed the front clip and dash design in 87. Also the air cleaner box is from a 94 to 97/8 7.3l powerstroke. First time I made a entry. First time I could sound like I knew what I was talking about.:D
Kayne
Savannah, Ga
You maybe right the rear end says V170A on the tag which according to ford is out of a 85-86 ford F350 and is a 10.25 dia. ring gear with a 4.10 ratio. I think the title says 89 tho and again i might not remember it right, ill check the vin on the truck as well as the id plate and title, as you can tell my GF was not above using things from other trucks, As for the XM757, to my understanding there is a junk yard some where near Henrietta Ok that my GF got the parts from and it was a stripped down truck, axles already removed and cab. He just went after the motor and trans. Note he had 1 old Deuce and a 5 ton from the same place and also out of this same junk yard he built a 55 ford on a 85 ford bronco frame. He sold the Deuce and 5 ton when he quit cutting wood for a living. Dont worry since ive mentioned the 55 ford ill post pics, note before anyone says impossible the frames dont match, originally you be right, the bronco frame was stretched by 4 inchs or so. My dad owns it currently, ive helped him rebuild the engine and put a new wiring harness in it. Back to the Beast as its know in my family, fluids levels all checked out. the only thing im worried about is algee in the fuel, the truck is almost empty of fuel tho. theres maybe a 1/8 of a inch in the tank, would some seafoam and fresh diesel do it. or you think or should i go ahead and flush the fuel system and change filters before i wake the Beast?
Any one wanna give there 2cents
cranetruck
94
Meadows of Dan, Virginia
Yes, it looks like it came from an xm757 (same as m656) alright.
Here are a few images of the engine. Fuel filters are different from the deuce and the primary strainer type, was mounted near the fuel tank on the frame.
The turbo is not a "C".
orren
26
Live Oak, Florida, USA
Primary fuel strainer
Bjorn,
Sure would like to have one of those primary strainers shown in your post.
Have any idea where I might get one, complete, in good condition?
Thanks for your help,
Orren Winjum
Kayne
Savannah, Ga
well i know the primary fuel filter that in you picture cranetruck is located on the frame rail for me. My G'pa put there for obvious reasons.
