retiredtoy
- 10
- 3
- Mexico, Missouri
I'm only 4 weeks old as far as being an SS member, but I really enjoy reading about all the experiences that I have already been there and done that. Guess I'm too old.
About the 15 KW gen. One thing to think of it that the 15kw rating is with using all three legs. When you use two legs, it knocks down your power output a third. And honestly, when I went through Missile Electronics (Guidance and Controls system mechanic on the Bomarc Missile) I think you multiplied the output times .707 for the actual RMS value. I'ts been a while since 1960 and I might not have that right. I do have one thing right though: There are inverters that are getting very cheap nodays that are designed to take the 3-phase power, rectify it to DC. then change it back to any voltage, frequency, or phase you would want. By using the inverter, you don't have to worry about changing the generator. Well I hate to waste all that I wrote, but I just thought of one other thing you would need with an inverter. A transformer so you could get the common for the two 120 volt circuits. The main advantage of the inverter is to obtain the full 15KW power out of your generator.
