emr
- 25
- 0
- landing , new jersey
Just wondering i like the goat idea, BUT what about the POSSUMS is what i want to know, wouldnt they help too
My deuce had two in it. One in a binder by itself and one in a binder with the lube order, MKT tech manual and several pages copied from the lube order that were laminated.gee U think they would come with them![]()
Hi Dan,Chuck,
To answer your question about the pump I have to say I do not know. The engine is a Hercules (not that it matters) and was rebuilt in 1993. I do know from an unfortunate experience that it will dump 5 gallons of oil on the floor in about 15 seconds or so through an incorrect oil filter gasket/oil can incompatability......... I run 20 quarts of 15w-40 and 2 quarts of Lucas just to give you info of what's in there.
That being said I'm not interested in the spin on upgrade. My grandfather's tractor has the exact same filter set up on it on the original engine from 1952 with over 21,000 hours on it and its still running. We never had a failure on it due to the filter set up.
Just let it idle chocked in neutral with the parking brake on. It will shut off when the diesel runs out.65 posts on a how to start a deuce thread, amazing, simply amazing.
RTFM
can someone tell us how to shut it off now?
So, Eric, I take it you would prefer that we just abuse the new guys rather than answer their questions?65 posts on a how to start a deuce thread, amazing, simply amazing.
RTFM
No, just simply direct them to the Manuals, and tell them to report back with any questions after reading it.
Obviously a polite and helpful explanation of how to use the TMs would help also.
edit, my RTFM comment was not directed at the OP, or anyone in particular.
It simply amazes me that everyone does not see the value of the TMs and offer that to every new person to the hobby.
WELL! Thats why invoked the possum rule so eloquently used here many times...65 posts on a how to start a deuce thread, amazing, simply amazing.
RTFM
OK, that would be the manuals section that we no longer can access, I guess...No, just simply direct them to the Manuals, and tell them to report back with any questions after reading it.
Yes, I'm an awful person. I respond to what you say, not to what you think.As usual, you missed the whole point of my(or others) posts and went off debating/disagreeing with each point of the comment(senselessly).
The OP's question was 100% answered within the first 5 posts. No need for any other discussion by the OP or others.
Sounds to me like he RTFM'd and found an inconsistency that bothered him, between a TM, and a PS magazine article, so he searched for a thread that discussed the issue, and posted his question. Exactly the technique that you say you prefer.Ok guys, I need a sanity check here. I have read the TM, the little operator manual cartoons and this thread and I have seen a lot of input that does not exactly line up with the published guides. Here is how I start my deuce:
1. Be sure stop switch is pushed in
2. Switch over the accessory switch, let it buzz for about 20 to 30 sec.
3. Push starter switch (but never for more than 5 to 10 sec., never pushing any pedal in and never pulling out any throttle cable)
4. After I do this about three to four times she will fire up (at this point I give her a little pedal to get her juices flowing, then I let her idle until she reaches 120 degrees and air pressure has built up, then I move out. She normally idles at 700 rpms)
After driving her, I always let her idle for 5 minutes to allow the turbo to cool before shutting her down and draining the air out of the tanks.
Am I missing something here? Should I be giving her some pedal while attempting to start her? The operator's manual says not to, to avoid creating a hydrostatic condition of access fuel in the cylinders. I let her buzz a little before pushing the start button, thinking this provides the fuel pump time to get the fuel moving through the system, am I wrong in doing this? She is parked on a slight incline with the engine uphill, maybe this causes the fuel to drain back into the system a little and that is why she does not fire up right away, but I don't think this is an issue. If it is not damaging I can try to give her a little pedal next time to see if she fires up faster.
Thanks.
DeuceDad
During the Vietnam War (I think) the Army noticed that the kids they were drafting didn't respond very well to the usual TM style of manual. Capitalizing on the comic book fad, they started publishing comic books that delved into all sorts of subjects that were important to the training, and lives of the soldiers. PS magazine is one such magazine that was aimed at the 18 YO's that inhabited the motor pool, and maintenance depots. The usual characters in PS magazine were gruff, but well seasoned Sargent types, dippy, ditsy mess-up privates, and a bevy of well endowed women that knew all the answers, and were willing to get dirty and greasy while demonstrating technique.
But I have to ask "what is PS magazine article"?
Thanks!!
-Chuck
