Runaway diesel and turbo issues
gimpyrobb
dumpsterlandingfromorbit!
27,786
759
Cincy Ohio
****, if your that far apart, I'd take the manifold off. Granted, you have to pull the intake at the same time to get the exhaust off...
The King Machine
92
Vancouver, British Columbia
When your spirit is fatigued, look to the power of beer to guide your through these times of mechanical madness.
these pieces of metal and steel will not hold you hostage.
you are in control and will be victorious.
remove that manifold!
The King Machine
92
Yes studs with nuts. Mine has studs threaded into the turbo flange and has a tack weld on the top of the flange to stop the stud from backing out. I have a busted stud there too. My plans is to drill it straight through then chase it with a tap after.
WTF D00D
St. Petersburg, Florida
Thanks guys, at least I know it is removable...lol..I wanted to have it ready for our Memorial Day event at work and that didn't happen, so I took the day off from heating, banging and twisting on that **** thing.
