Running Hmmwv wheels question
481
10
Charlotte, MI
One thing to pay attention to with the HMMVW rims is making sure the two halves are centered. Two of the four that I mounted on my 08 had a total of 1/4" runout on the inner piece while the outboard portions were all fine.
The early style 12 bolts need to be centered with at least three centering washers per wheel. The later 12 bolts are supposedly self centering if you line up the inner centering hole with the outer one.
If anyone can get these to run smoothly though, let me know how you did it.
1StumpJumper
NW Washington
I ended up going with some stock steel wheels until I can put some time into the 12 bolt rims. FYI, the tires still took between 12-16 oz of weight per wheel.
Varyag
Garfield, Washington
patracy, Thanks for the info. I'll take my chances and run the 37s, but keep an eye on them and check the rims regularly for anything fishy going on! I have been looking into getting a remote tire pressure gauge setup to, but am having trouble finding a system that will work with the internal bead locks. Maybe I can grind down the PVC insert a little more to accommodate one of the sets that I have found.
Don't hang out around the wheel as you inflate especially if you are running 37 pressure. I wasn't in the shop but I heard it when it went off. The mechanics had the rim in cage with a remote air line, to their credit. When I ran in to see what had happened I saw that when the rim split it blew out the bars pretty nice.
