S-250 Shelter Power Receptical Question
Skinny
492
Portsmouth, NH
Are you running something 208v 3 phase in the shelter? Why not convert to single phase 120v so you have the ability to plug the shelter in to conventional residential or generator power? I required my M1031 to 120/240 with an L14-30 plug so my truck would be useable. Of course you may need it for some 3 phase military or commercial gear.
dtdoyle01
Tucson, AZ
I actually striped out all the 208 3 phase wiring and rewired for 110. I picked up the 3 pin connector and made a cable to power the shelter. Now that it is getting hot here in Arizona, 101, 3 days ago. I am going to gut the 208 AC unit on the front of the shelter and install a 110 AC in the existing case, so as not to change the look of the truck. I power the shelter in the field with a Beem 3000 watt propane generator.
tim292stro
40
S.F. Bay Area/California
240 is still single phase, unless it's three phase delta. The two 120 "phases" you find in residential are from a center-tapped 240V transformer (center tap is neutral, and grounded). For a 3-phase AC that doesn't use the neutral, a 240V single phase supply wouldn't work - two of the three phases would be "dead".
It's better in my opinion to take a procedural approach to this decision tree:
  • Does the AC require 3-phase power?
    • Yes. Are you able to provide 3-phase power?
      • Yes. Provide 3-phase power. Done.
      • No. Find a different AC to use that runs on the power you can provide. Done.
    • No. Does the AC support the voltage range from your single phase source?
      • Yes. Will you generator support the surge start requirement of the compressor and the other concurrent loads at the voltage you can provide?
        • Yes. Will the BTU output be sufficient with the different single phase voltage can provide?
          • Yes. Provide single phase power. Done.
If you can't figure out the answers to these questions, and are not familiar with AC specification in general - it might behoove you to re-frame the question in more simple terms.
rmgill
14
Decatur, Ga
208 made from two of the three phases (120 vac phase to ground) of a three phase system will power most items that will run off of 240 volt from single phase systems. That was the angle I was driving at. Now if the device really needs all three phases, then yeah, residential power won't work.
I guess I wasn't entirely clear.
