metalworker393
- 24
- 18
- Jackson NJ
Hello and how are you all doing today. So I have a question regarding my fuel system on my genset. I have an MEP 002 for my backup power. I usually start it up and run it for a half an hour a month to keep it ready to go . I had a larger fuel tank made for it after hurricane Sandy, that way I would only have to refill the tank once a day. ( yes there is a float switch, I don't trust it after what happened to our generator at work).
So I usually keep fresh diesel in it, but not running it for an extended time, what should I do about keeping the system clean? I have been reading about sea foam for vehicles, what would be a recommended amount to use if I wanted to add this to my fuel system? I usually add a lubricant to the diesel since I am using low Sulphur diesel. Want to keep it clean, but don't want to damage the IP either. Any input would be appreciated, Thanks, metalworker393
