Seems like this is turning into a build thread.
CARC686
706
New Mexico
Rain and snow sounds wonderful. I'm just glad it's not 120 degrees every day like it was last year. I could work on the truck from about 6:30-7:00 AM last summer before my sunburn in February skin made me retreat back to my hole in the wall.
CARC686
706
New Mexico
So the hub I replaced is fine, but the one on the other side was getting so hot, it was probably just shy of glowing in the dark. Naturally, every single part was seized and I mean every single part. The big hammer did a whole lot of sweet talking. The grease was like clay and the bearings were pretty much bone dry, but it's a testament to American materials of yesteryear that I would rate the OEM bearings about 10% worn. They went right back in as hand packed grease cakes. Near as I can tell, whoever was in there last took all the parts for both front hubs and stuffed them in one side. I don't know how they fit all that junk in there, but I put it back together IAW the TM. After some freeway driving, I grabbed the hub and it was cooler to the touch than my hood.
CARC686
706
New Mexico
Yeah, I just noticed it dripped on the pavement where I was doing the hub. I resealed it last year and if it dripped once in a few hours, it has dripped hundreds of times. I used nothing but sealant on it last time, but evidently, I didn't get it clean and dry enough, and made a mess of the job in spite of having hand polished the cover to bare metal before refinishing it in hi-temp lacquer. The sealant ended up all over the place, and by the time I was done, I had a feeling it was going to leak. Crawling around under the truck while it's parked on sand is such a pain in the ass.
CARC686
706
New Mexico
I found an aluminum silicone composite gasket from a company called Lube Locker. Ought to save me from smearing RTV all over my pretty cast iron diff cover.
CARC686
706
New Mexico
I picked up a HMMWV pioneer kit awhile ago and pulled it out recently. Axe handle was chunked out and it had a pretty good wobble, so I rehung my first axe head today. That job was a lot harder than I expected it to be and the end results are pretty ugly, but it's rock solid. Fingers crossed it stays that way. Any tips from you folks up in the sticks to do a better job next time?
Super fugly wedge work:
CARC686
706
New Mexico
Scrubbed the pioneer kit rack down and decided the straps were too dried up to be trusted in the desert sun, so I cut them off. Getting replaced with ratchet straps.
The rack just got a coat of Rapco 686. The retainers were attached to L-bracket adapters, so I removed them. I believe in the current configuration, this should clamp onto the bed rail in my M1009.
Tools sharpened and painted two tone 686 and black. The wood grain looked nice after being sanded down, but the sun would rot it away, so I covered it up.
20,736
You might consider @Valence for straps.
CARC686
706
New Mexico
I had wanted to mount it in the window, but it appears that it will not fit without more modification than I care to do, plus with my luck sudden side loading would cause it to bash my glass out. For now, it's secured and out of the way. Will figure out a hard mount solution when the daily highs come down 10 or 20 degrees.
CUCV VZ
13
Flint, Michigan
That is a pretty nifty little kit there.
Is the cable from the topper original to these trucks? If not just curious as to what you use it for.
CARC686
706
New Mexico
Yeah, it's OE for the CUCV. The radio it was attached to was so heavy, I could feel the difference when I removed it.
CARC686
706
New Mexico
Been collecting stuff since I noticed the drip. Nice, bright diff cover to keep company with my nice, bright suspension bushings. Somebody bought it for a Dana and it didn't fit. Their loss, my gain. Looking at this brings a thought to mind. I always seal inboard of the fasteners so oil can't leak through the threads. The silicone beads on this gasket are outboard of the fasteners. The literature with the Lube Locker gasket claims that no sealant is necessary. They have good reviews. I will probably seal the threads on the fasteners anyway. I don't trust it. Irritating. The point of the gasket was to completely avoid handling adhesive while rolling around in the sand. Oh well. Hopefully, the diff cover will never need to be removed again. One can dream.
dougco1
705
Cooperstown NY
That should make your ride run better. If not, like you said, it will complement your bushings.;)
CARC686
706
New Mexico
That should make ride run better. If not, like you said, it will complement your bushings.;)
You jest, but in truth, I'm putting Royal Purple in it this time. It will measurably improve my MPGs, but I won't notice because I don't pay attention. I know all the shiny crap I put on this truck is lowering the resale value, but that's a problem for whoever nabs it when I'm gone.
dougco1
705
Cooperstown NY
ROYAL PURPLE PERFORMANCE ADVANTAGES
  • Maximizes horsepower
  • Extends gear and bearing life
  • Reduces operating temperature
  • Lower coefficient of friction
  • Superior corrosion protection
  • Separates rapidly from water
  • For use with open, limited-slip and locking differential
  • Contains limited-slip friction modifier
Very impressive claims.
Now where does it say it measurably improves MPGs? :unsure:
