- 298
- 8
- 18
- Roswell, NM
I found a slight problem?!?!? It seems my front steering box leaks from the bottom seal where it connects into the linkage that turns the rear steering box. Its a pretty substantial leak. I also noticed when I try to turn the steering wheel it just doesn't feel right. It has a gritty feel. The wheels turn, something just doesn't feel right?
Do all goats feel this way when they steer?
Would you replace the entire steering box and the steering column? Or just the box? Or is there a way to only replace that lower half of the box?
Let me know your thoughts.
I have a very long road going to my house and I and was able to get her into 3rd gear. Good GOD you really have to wind it out to get it into third. Everything worked great. The transmission shifted perfectly. I also was able to shift from hi to low range and was able to engage the 6-wheel drive as well. Everything went into gear smoothly. Also, The trailer turned and tracked very well. Ihave never driven a goat and I must say it is pretty cool seeing the trailer turn with you. That dual steering is pretty slick
