Sheared Winch Shear Pin... Getting the old one out??
sailor2000
Houston Texas
How do you line up the holes in the u-joint collar with the old shear pin so you can drive it out?? I have no doubt it is simple, but I can't seem to get it done....
oilcan
Ohio
You should be able to get the shaft to turn to line the holes up n' knock it out. Throw the lever on the winch and spin the drum a little...
sailor2000
Houston Texas
Re: RE: Sheared Winch Shear Pin... Getting the old one out??
Since I can't see into the hole, how do I know when the holes are lined up??
DavidB
33
Southeast Wi.
Truck parked, E brake on,engine off,PTO/transfer/transmission in neutral.WINCH ENGAGED with drum lock on this will hold winch in one spot. Turn shaft until holes line up, remove old pin,replace with new.Disengage winch job is now complete.This is my method, it has been awhile since I have broken one though.
DavidB
oilcan
Ohio
RE: Re: RE: Sheared Winch Shear Pin... Getting the old one o
To be honest, I've only changed mine once. If I remember right, I could slide the shaft back away from the winch enough to see the edge of the shear pin hole. I just lined the hole on the shaft (kinda) and slid it back on. It took a little jiggling at that point, but in a couple of minuites, I was done.
