Shelter to Camper Conversion....
RAYZER
59
sanford/florida
Excellent work sir! The bow slats on the bed is a great idea.
This shelter is 14.5' long? That's some good space!
I would like to see some exterior pic's of the shelter.
59apache
Chipmaker
1,299
30
Bavaria / Germany
thanks at all!
Ray, your own work set the benchmark.
I trial to make a clean and rugged installation. it was a lot of work, removing the old installation, ( felt 100.000 rivets :lol: ), fill the holes with bondo, sanding, fiberglass wallpaper, paint with concrete colour....works very well.
Now its halftime.
Missing:
shower, benchseats, heater, electric, lights, ASO
59apache
Chipmaker
1,299
30
Bavaria / Germany
i've made a cabinet for the gas bottle, from outside accesible gas-tight to the inside.
the wood is painted with liquid plastic, all seams are sealed.
And with a large vent hole on the bottom.
59apache
Chipmaker
1,299
30
Bavaria / Germany
progress
next chapter...eletric & lighting
plan: furniture spots (they called Moebelleuchte in german) they are original made for lighting in display cases with LEDs instead of halogen bulbs...
in dibond (alu plastik sandwich) panels
first i have to make brackets....
step 1 lasercut brackets
step2 make a punch & die
bend
panels & brackets
59apache
Chipmaker
1,299
30
Bavaria / Germany
more...
i want to switch the last 3 lights separate and all together so i mount this diode.....in a fuse holder:-D
switch at the bed
LIGHT!!
59apache
Chipmaker
1,299
30
Bavaria / Germany
under the bench...
fuse and GFI for 220V , socket for battery charger, switch between "shore power" and inverter
pure sine inverter 1500W con. 3000W short, battery charger for gel charging and powersupply , distribution box
CombatVet
Delaware
That is excellent work you have done. Very well planned and executed. You inspire me to achieve such quality work and detail in my future MV RV build. I am subscribing to follow your progress :)
59apache
Chipmaker
1,299
30
Bavaria / Germany
the cable is welding machine cable, very flexible and easy to install. a single wire is only 0,2mm thick!
cable lugs are crimped on, not soldered. soldereds loose their flexibility and tend to break.
stay away from car audio cables, their often CCA that means copper clad aluminium cable, you can hardly tell the difference from looking, only the weight tells.
and it has much less conductivity......
sorry for the pics, camera makes no better ....
