Shelter to Camper Conversion....
59apache
Chipmaker
1,299
30
Bavaria / Germany
Do you plan on doing anything over the bed as far as storage goes
not yet. I have much space under the bed, the storage boxes, the back side of one bench, the "chest" under the other, i hope its enough.
its hard to translate it..i hope that makes sense to you....
i like the feeling of space, nothing is claustrophobic in this box.
59apache
Chipmaker
1,299
30
Bavaria / Germany
this weekends progress....building a frame for the battery box (its a sealed box, made for that.) riveted to the floor
modified the box (eliminate the pigs nose/ slave port)
and finished the elektric
missing:
wires between the battery poles, connection from the box to the heavy duty fuse, outside slave port for connecting trucks 12V system to the shelter and the 220V inlet....
peanuts!:p
and making a connection for the box vent tubes to the outside....
the batterys are sealed, but its a safety thing to make a gas-tight connection to the outside....
59apache
Chipmaker
1,299
30
Bavaria / Germany
next chapter....water & shower
i want a shower, but shower tubs for houses are to big and to heavy, for RV to lousy, custom made's unpayable....so i've decided to make my own.
stainless steel, 1mm, cut, bend, corners TIG welded.
the carrier is made out of a 8mm waterresitent wooden board, original for trailer beds....and 40mm styrodur.
the drains (correct word?) are in all 4 corners....
for the hole i made a punch and die.....works good!
mounted..
59apache
Chipmaker
1,299
30
Bavaria / Germany
all grey water tubes go to 1 connection point under the shower.
i've made a kind of syphon and connector.
its mounted on the wooden board of the carrier and goes trough the floor to the outside.
Kohburn
SOMD
the 4 corner drains vs a single center drain makes a lot more sense in a platform that is likely to not be perfectly level. Smart move.
59apache
Chipmaker
1,299
30
Bavaria / Germany
heater & ducts
heater is a TRUMA E4000 , needs very low electricity, exhaust goes through the wall (not yet, after painting...:-D)
ducts are made out of 1mm aluminium sheet metal. they're only for appearance, the warm air goes through a special hose. Oulets are 2 under the table, 1 close to the bed in the bench, 1 in the other bench. there is a butterfly valve in one line, so you can regulate the airflow.
59apache
Chipmaker
1,299
30
Bavaria / Germany
furniture...
not much to say about. I'm a chipmaker, metalworkig is my world.
i've done my best, a pro carpenter would make it better.
measure, cut, sand, paint, sand, paint again...
I've made everythig out of 15mm lumber core plywood, except the seat and the dividing wall. They're 19mm.
At the corners i've used 30mm angle aluminium, 3mm thick. they com in 6m pieces...a lot of measuring,cutting and drilling
on acces plates i'v used rivet nuts. nice to work with.
59apache
Chipmaker
1,299
30
Bavaria / Germany
PETEC bodywork adhesive and sealant, it's a Polyurethane based adhesive, aplied with a toothed, notched whatever trowel. The PCV is simply pressed on with a rubber roller. no fancy stuff like a veneer press is necessary.
