shelter's
nf6x
Feral Engineer
1,630
51
Riverside, CA, USA
Re: RE: shelter
CCATLETT1984 said:
S250 or S270
An S-250 would be awfully small for a deuce; they would normally go on a HMMWV, Gama Goat, CUCV, etc.
The S-280 and its various cousins are the right size to fill the deuce bed.
I'm not familiar with the S-270 yet.
I don't know of any particular sources for them at the moment, but here are a couple of files that might prove interesting.
I have pictures of my S-448 (a cousin of the S-280) on my web page, and I have an S-250 mounted on my HMMWV.
doghead
4 Star General /Moderator
1,191
NY
RE: Re: RE: shelter
Our state DOT gets them before they ever make it to auction, here. They have them lined up in rows along fences surrounding the different sites and use them as sheds for storage.
RE: Re: RE: shelter
Thanks for all the responses was hoping to find something closer to home now i no what fits i think i am going to look for the 280 or s371 maybe even look for a 109 box someone has taken off for some reason unknown Thanks again
jim-m35a2
Michigan
How would one get a 12 foot shelter in and out of the bed of a Deuce without a overhead crane or wrecker. I saw where one was installed using a front end loader.
Jim
________
Paxil lawsuites
nf6x
Feral Engineer
1,630
51
Riverside, CA, USA
Maybe with a flatbed wrecker from the local towing company? I'm not sure if its bed would be high enough to line up with the deuce's bed, but if it was, then the wrecker could winch the shelter up onto its bed, and then you could use a winch or come-along to drag it onto the deuce. I've used this trick to offload a scissor lift from a semitrailer. I don't remember the bed height of the flatbed wrecker, though. If the wrecker's bed was a bit too low, maybe you could back the deuce up to a berm that would let the wrecker get the shelter up above the edge of the deuce's bed.
Take a look at the pictures at the following link, showing how a commercial wrecker offloaded my M543A2 military wrecker from the semitrailer that it came on. They might give you some ideas. With a bit of ingenuity, the local towing companies can come in handy when you need to load/unload truck shipments without your own facilities or equipment!
http://www.nf6x.net/greentruck/truck3/pics.html
Believe it or not, I loaded mine by jacking and stacking pallets under the front of my shelter then using a come-along thru a snatch block to both bottom corners of the shelter and easily pulled it onto my duece.
And if I hadent done it in the dark with flashlights, I would have pictures of it :wink:
But as you see it sitting on the trailer, I disconnected from the pickup, backed the duece over the toung jack of the trailer, stacked many pallets under the front of the shelter and pulled it up onto the duece. Once it got 51% of the weight over the edge, it gently landed on the deck, then I just positioned it.
This is a s371 shelter (now being converted to a camper)
Davidwyby
244
CA
I moved a lot of buildings with a rolling tailboard flatbed when I lived in Midland. Works great!
