WARWAG
- 25
- 38
I have an 86 M1028 with a 6.2 with 54,XXX original miles (On the truck at least). The engine has a HMMWV oil pan I'm told. So I am not sure if its the original engine but suspect it is. I'm looking into replacing the engine with a P400. I have seen ratings from 190 NA up to 250 HP (Turbo) with 550 Ft Lbs. I like those numbers. Anyone else have any suggestions or ideas at what I should look at. If the P400 is the best then who would you suggest I contact? I will replace the engine in February. I will keep the good stock engine and tinker around with it for a possible buggy install I want to do down the road. Thanks for any help.
