parlusk
- 3
- 18
- southwest virginia
I have had fuel problems since I have gotten this 09 running a couple of years ago. First off it was air in the fuel then water. I have installed a spin on fuel filter and that solved my problem until the other day. After driving up to a friends hunting cabin it died when I got back on the main road. I let it sit for a couple of minutes then it fired back up I would rev it up with no problems but as soon as it went back up the road it would die. I was able to let it sit for a couple of days and was able to make it so some rental properties that we own. I went down saturday with a inline fuel pump and a 2 gallon can of diesel. I plumed in the inline pump to the fuel can and routed my original fuel line into a jug under the hood. There was a ton of air in my system but after running for about 15 minutes it smoothed out and i was able to make it home. When it first started the mechanical fuel pump was pumping good, but i noticed when i got home it was not pumping much at all. I have never knows a lift pump only to go bad after warming up, so i am thinking I have algae or something in my tank clogging my sock up. Is there anything else that i am missing before I drop the tank?
