Simple fix for broken CUCV transfer case indicator
TexAndy
Bee County, Texas
The indicator bar on my transfer case didn't show any "bubble."
So I took it apart and discovered what the problem was. The bubble is part of a single hard plastic piece which has two arms that capture the transfer case selector lever so that the lever moves the bubble up and down the glass window on the face of the black plastic cover.
One of the arms was broken.
I tried gluing the broken piece back on, but predictably, the glue didn't hold long. Some plastics just don't glue well and I suspect this is one.
Luckily, I had some scrap polycarbonate (very hard, durable plastic) pieces in the shop. So I cut an L-shaped one, sanded down the "hump" on the original piece so it had a flat surface, and screwed the L-piece to it. Easy peasy.
Works great now. I also repainted the bubble as it was totally faded. I didn't have any orange paint, so I used red model paint.
Anyways, here's some pics.
cucvrus
10,505
Jonestown Pennsylvania
Nice fix. May I suggest that you move the 4WD indicator wires to the outside of the firewall and to the transfer case switch. It is just an idea. And it cleans up the floor from the wires. I do all mine that way and then run a light into the transfer case shifter indicator mechanism so it is lit at night when the park lights are on. I run them wires up from the bottom also and use the same type of plug as the front fender marker lights. It is just an idea and any easy update. Also I have a shifter knob from the upullit that came from an Nissan Pathfinder. Has the same shift pattern embossed on the knob. Drilled the hole out and tapped it, it fits right on the shift handle.
TexAndy
Bee County, Texas
My switch doesn't work. I jumped the switch wires and got the light to come on that way.
I've been trying for the past couple of hours to remove the switch. I can get a wrench on it, but I can't get it to budge. And there's no room to get a cheater on the wrench.
