Skytrak 6000m attachments
ColdMike
Minnesota
I have a Skytrak or Sky Trak 6000m. I want to put a quick attach conversion on it so I can use rental grapple buckets or other attachments.
Anyone have experiance with this? I'm not familiar with hydraulic flows and pressures, do you see any redflags using a grapple bucket with the OEM hydraulics?
Thanks all!
tmuenster
111
31
TN
ColdMike, I put a skidsteer-style quick attach adapter on my military Terex TM51-19, which is a 13,500lbs telehandler. It is pretty handy to switch out forks, rock buckets, standard buckets, etc. I also have a grapple but there were two issues using it on my little telehandler- the weight of the GrabTec GDX grapple is about 2000 lbs and the hydraulics at the end of the boom do not have the volume of flow needed to make it work. I think your Skytrak is a heavier machine and could handle the weight better. The lower flow of hydraulic oil would reduce the cycle time and gripping force for a grapple. Good luck with your project! Tom
Sent from my iPad using Tapatalk
