Snow Plow Installation: Meyer from about the mid-80's. HELP??
rhinob
Ijamsville, MD
Greetings,
Just found a complete Meyer plow for my CUCV M1009 and I'm looking for some detailed photos of the installation. Can anyone supply them? This plow is a 7' Meyer from about the mid-80's and is not an EZ-Classic tubular type.
Thanks much!
Den
m1010plowboy
2,983
Edmonton, Canada
Pictures are good. I'll show you my plow if .....
I went to google and searched ......"steel soldiers" plow.....
Under the first SS link on google there is a blue link that says ..............More results from steel soldiers.com
When you hit that you get a few pages of threads, well .....a few hundred pages of threads, where someone on Steel Soldiers used the word 'plow' 'plowing' 'plowboy' or something like that. You can change your search by adding the term "CUCV" to "Steel Soldiers" plow but I found a ton of pictures and info on the first search.
I think this link was on the third page in and there are plenty o' plow pages to ponder.
http://www.steelsoldiers.com/showthread.php?44059-Custom-Plow-setup-for-my-CUCV
wayne pick
Valley Cottage NY
Note- You may or may not have to drill bolt holes in the frame to install the lower mounts. Be very carefull, as there may be steel brake lines inside the frame rails. they were exactly where I had to drill 5/8 holes on my 1031 when I installed my fisher setup. I bent them slightly, and re clamped them to the frame.
