aztec
- 2
- 8
- dunnellon florida
ordered pac brake 3k-4k springs anybody got install instructions
It comes with them, I bought the same GSK and have not installed them yet. If I remember correctly, it says to measure the stock retainer height first, remove and swap springs while leaving the inner one (?), and then set the retainer height to the same as original, say 0.050" for example.ordered pac brake 3k-4k springs anybody got install instructions
It wasn't a required thing, it just made it easier to do. The 14mm nut fits pretty tight, so it is actually faster to back out the 10mm, then back out the 14 to meet it. The socket was a gift from a 5 ton owner with a lathe.Why did you need the special socket? Could you have loosened the 10mm and then just put a 14mm in there to turn the nut or did I miss something? Does the 14mm need to be held for some reason?
There are many different marine injectors for an 8.3, and I believe the people posting that were referring to a 5.9 with the 370 marine injectors. I have seen 5 or 6 part numbers for 450-480 injectors for an 8.3. Of course, the best ones cost the most. I just don't have exact spec for them because they are direct from Cummins. I'll get the details soon though. They make 350hp (give or take a bit)with these MWpumps.You know... After reading through this thread multiple times, I think I'm more confused than well informed
So far I've gathered the following helpful bits of data:
-The 8.3 is easy to turn up, and is rated for 3,000rpm
-Don't use the marine injectors, because the spray angle is not right for our engines
-Keep EGT's below 12-1300 degrees
-Be extremely careful when modifying the pump, as some of the small parts are very easy to lose
-It's best to add upgraded governor springs when doing pump mods, so you will keep the fuel from cutting out under hard acceleration
Does that sound about right? I'm still trying to figure out all of the settings, etc. I would love to bring my 8.3 up to 300hp. So far all I have done is upgrade the air filter with a new one from TMG, and add the new cage that they made. Soon I will be buying and installing the pyrometer/boost gauge they sell that mounts on the dash. After that, I'm still not sure exactly what to do.
Good to knowThere are many different marine injectors for an 8.3, and I believe the people posting that were referring to a 5.9 with the 370 marine injectors. I have seen 5 or 6 part numbers for 450-480 injectors for an 8.3. Of course, the best ones cost the most. I just don't have exact spec for them because they are direct from Cummins. I'll get the details soon though. They make 350hp with these MWpumps.
You missed one thing you really need to put an EGT on it and this is not the same pump used in the normal rv's or tractors but yes the motor will rev much higher I am going to turn low fuel back down a bit and get new springsYou know... After reading through this thread multiple times, I think I'm more confused than well informed
Pyrometer measures EGTYou missed one thing you really need to put an EGT on it and this is not the same pump used in the normal rv's or tractors but yes the motor will rev much higher I am going to turn low fuel back down a bit and get new springs
Pic of your special tool?Some pumps have a different nut in place of the 10mm I made this tool from a socket and just cut down the sides to make a spanner socket..
Edit this 2nd photo is of the more common locking 10mm nut...
What are you buying me?Pyrometer measures EGTIn my post I mentioned that I will be installing one soon. Just have to hold off on more mods because I am spending so much on Christmas presents.
Ummmmm, really?Pic of your special tool?
