Spare parts question
cbisson
309
NH
A while back Guyfang provided me with a list of spare parts for an 802a that would be good to have on hand. One item was listed as "diodes for the main gen". I can't seem to find them in the -24P, at least to the point that I'm sure of what he is referencing. Guyfang, could you please be more specific or point me in the right direction?
Thanks
-Craig
fa35jsf
35
OKC, OK
Maybe he is referring the diodes in the voltage regulator. They can be damaged in some cases by very high voltage spikes.
I posted awhile back on how to change out those diodes and upgrade them to higher voltage rating. I’ll have to go find it.
kloppk
4,198
Massachusetts
There are two diode assemblies in the gen head.
5961-01-019-8003 Onan PN 358-0070 Can be found on ebay
and
5961-01-021-2232 Onan PN 358-0069 Can be found on ebay
Guyfang
27,237
Burgkunstadt, Germany
@Guyfang might it be possible to get the link to such a magical list?
Sent from my SM-G970U using Tapatalk
Well, I think way back when we made something like that list. But lots of folks feel that once you start, there is no end in sight. As a self confirmed horder. I have to agree. Sure, we could sit down and hammer out a list. But man might need deep pockets for it, and most of what you buy will not be needed in this life time. Just when you think something is not needed, that part fails. But I would start a new thread to do it. Start new.
cbisson
309
NH
This is the list I'm working with. I have most of the parts on hand. Still working on some like the LOP switch, diodes, etc.
1 ea. A1 Volt reg
1 ea. Plastic relay
1 ea. 24 volt alternator
1 ea. K4
1 ea. K1
1 ea. K2
1 ea. K8
1 ea. S14
1 ea. A9
Diodes for the main gen
1 ea. Low oil pressure switch
1 ea. Engine over temp switch
1 ea. MPU
1 ea. Water pump and gaskets
1 ea. set of injector pumps and injectors
1 ea. Starter
1 ea. E1 and E2 fuel pump
1 ea. package of both fuses needed.
Jeepadict
783
Round Mountain, NV
I've recently come across these little guys. Seems to be a good combo visually without seeing a breakdown list. Is it wort the trouble to hold things like this if a guy cod find it for his model? Anyone know where this would be in the TM?...can't seem to find it.
Light in the Dark
6,775
MA
Yep, I have all that info......just can't find the dang thing configured as they are on the sets, with the wires coming out of the switch as opposed to screw terminals.
Thanks LITD.
Worst case just make some small jumper cables with ring terminals one one side, and disconnects on the other. If there is a will, there is a way.
Guyfang
27,237
This is a good place to start.
15KW TQG OIL – 300 HRS Breather 750 hrs. Coolant 1500 hrs.
**SECONDARY FUEL BOWL DOES NOT HAVE A FILTER, if blocked, remove**​
OUTER AIR FILTER 2940-01-103-3268 As Necessary
INNER AIR FILTER 2940-01-103-3267 As Necessary
FUEL FILTER 2940-01-376-5666 300 hrs.
OIL FILTER 2910-01-360-6368(Baldwin) 01-493-4533 (Isuzu, Smaller) 300 hrs.
O-RING, Secondary FUEL BOWL 5330-01-382-5915 Replace as necessary
Valve Adjustment (Cover Gasket) 5330-01-361-7915 3000 hrs. Head bolts 1500 hrs.
Injector Test/Replacement 2910-01-361-0616 3000 hrs
Injector Gaskets 5310-01-226-6661 and 5310-01-224-9107
30KW TQG A&B Models OILA&B – 300 HRS Coolant A-1500Hrs; B-300hrs.
A B
ELEMENT AIR FILTER 4130-01-378-1130 300Hrs. 4130-01-378-1130 As Necessary
FUEL FILTER ELEMENT 2910-01-359-4971 300Hrs 2910-01-444-3758 300 hrs.
FUEL FILTER WASHER 5310-01-395-8744 300Hrs. 5330-01-452-0929 300 hrs.
Fuel Filter kit valve: 2915-01-470-1640 As Necessary
Fuel Valve Seal Kit: 5330-01-452-1310 As Necessary
OIL FILTER 2940-00-007-4791 300Hrs. 4330-01-444-3729 300 hrs.
Breather Filter 2940-01-406-9542 750 Hrs. 2940-01-470-6444 300 hrs.
Valve Adjustment (Cover Gasket) 5331-01-197-0905 3000Hrs 5330-01-470-6706 1500 hrs.
Injector Test/Replacement 2910-01-333-2309 3000Hrs. 2910-01-460-8973 1500 hrs.
5331-01-333-2698
Guyfang
27,237
I take that back. This is from FEDLOG.
CONSISTS OF THE FOLLOWING: 5305013656313 SCREW CAP HEX 25EA, 5310002748710 WASHER LOCK 10EA, 5310012349416 WASHER FLAT 10EA, 5310009038595 NUT PLAIN 10EA, 5306013667075 BOLT MACH 15EA, 5310002748715 WASHER LOCK 10EA, 5310008094058 WASHER FLAT 10EA, 5340002970312 RETAINER NUT 10EA, 5310014666312 NUT PLAIN HEX 10EA, 5310010123595 NUT PLAIN ASSY 25EA, 5306011567663 BOLT MACHINE 25EA, 5945004583351 RELAY ELECT 8EA, 5945013659954 RELAY ELECT 1EA, 5930015312976 SWITCH ROTARY 1EA, 5930015312975 SWITCH ROTARY 1EA, 6240001433060 LAMP INCAND 2EA, 6240014704272 LAMP INCAND 3EA, 5920002422706 FUSEHOLDER 1EA, 5920002433787 FUSE CART 1EA, 5920008166892 FUSEHOLDER 1EA, 5920002850901 FUSE CART 1EA, 5940014252020 TERMINAL LUG 1EA, 5940011129746 TERMINAL 2EA, 6145011299955 CABLE SPECIAL 1FT, 5305009580340 SCREW MACH 1EA, 5310000145880 WASHER FLAT 1EA, 5975007275153 STRAP TIEDOWN 3EA, 294001103268 FILTER 1EA, 2940011033267 FILTER 1EA, 4720013851102 HOSE PRE 1EA,
8CONT FROM FEATS: 4720013685430 HOSE PRE 1EA, 4720013740783 HOSE PRE 1EA, 3030010174340 BELT V 1EA, 3110013048142 BEARING BALL 1EA, 5331013744468 O-RING 1EA, 6620012207105 THERMOSTAT 1EA, 5330014133723 GASKET 1EA, 4720013822845 HOSE PRE 1EA, 4720013941931 HOSE ASSY 1EA, 4720013751391 HOSE ASSY 1EA, 4720009135910 HOSE NONMETALLIC 7FT, 4720013667172 HOSE ASSY 1FT, 2910013765666 FLITER FLUID 1EA, 2940013656535 FILTER BODY 1EA, 5310011971473 NUT SLEEVE 5EA, 5330013662836 GASKET 3EA, 4720013920319 HOSE PRE 1EA, 5310012249108 WASHER FLAT 10EA, 5310012266661 WASHER 4EA, 5310012249107 WASHER 4EA, 2910013633087 FILTER FLUID 1EA, 5330013811934 GASKET 1EA, 4820661285601 VALVE 1EA, 5331013617915 O-RING 1EA, 5330012264455 GASKET 2EA, 2940014934533 FILTER ELEM 1EA,
