kfrosty
- 5
- 0
- Belmont, NC
Speedometer isn't working, tracing it back and I think one of the shafts tips in my Drive Pinion is broke off in the Speedometer adapter.
Here's a pix where I unscrewed the housing so the entire shaft can be seen. It's rigged at the tip like has broke.
Figure 488 in TM 9-2320-280-24P-2 a Pin Shoulder Headle, part # 30448-D but I'm not sure if that's something different.
The part # it shows for the Adapter is SP-311. I've only found it one place and it's $123. I'm hoping to figure out an alternative. I've still got to pull out PN 3212735, the Helical Geashaft and inspect it. I think the cable is mess up and the tip of the adapter broke.
Here is the figure from the TM.
Item 1 & 24 are what I'm talking about. Item 1, the tip of the shaft that goes into item 19 is what looks to be broken.
I'm hoping 1 can be found on another application using an NP 242 or there is a way to find the replacement shaft/pinion that goes inside Item 1.
Thoughts?
Thoughts?
