Stalled Deuce
devilman96
17
Boca Raton, FL
I need to update the TA with a second option, there is another location for bolting the Napa filter and you don't have to cut the OEM mount... I actually opted to put mine in a different location as it made keeping the truck running while painting the front of the frame possible.
If you look under the alternator there are (2) 3/4 bolt holes that go into the block... If ya go to the local hardware store and get yourself a piece of 3" wide flat bar and (2) 3/4x1" bolts and lock washers you can mount the filter on the side of the block, not modify the original parts, and still gain the alternator adjustment room...
One way lets you save a few pennies and not buy as much, the other lets you save your oem parts...
2deuce
186
portland, oregon
I went and ordered the 4309 and 3418. The 4309 is flowing the wrong way to put it in the stock location. Putting it on the engine turns it around and solves the flow direction problem. I don't know if my lines are long enough to reach that location. I'll have to check. Greg
JDToumanian
14
Phelan, CA
Devilman - Just a thought here, but I wonder about metal fatigue of the copper lines due to the vibration of the engine? I think that's the reason the lines always change from copper to rubber when they get to the engine... copper will eventually crack.
Something to keep an eye on anyway...
Regards,
Jon
houdel
11
Chase, MI
Actually, I think the original parts are nylon with flare and/or compression fitting. At least on my truck. Nylon works and lasts a lot longer than rubber.
2deuce
186
portland, oregon
From what I can see in the dark with a flashlight those 2 - 3/4" holes are used for the motor mount on my truck. Maybe your motor mount is different from my truck.
Greg
1,824
Greg, you are absolutely correct. There are 2 styles of front mounts. A U shaped one that bolts where Mike put his filter ( both sides) and the one that has ears on the front of the engine. BTW, the one with the ears has a removable crossmember, the one with the U doesn't.
