Standard HMMWV antenna for cb antenna?
Sgthoffer
West Virginia
I searched but its hard to find stuff on here.
Can you use a standard HMMWV antenna with a cobra style cb radio? If so what adapters do you need to use?
Any help would be appreciated.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Find a MX-6707 Base and AS-1739 antenna on the bottom of the MX-6707 is adjustable Coil switch I have used them for 11 meter CB band and Ham bands 6 meter and 20 Meter also make shure to ground the Antenna base and The radio and body are Grounded good with Copper grounding straps.
the VSWR will be very good and the grounding act like counter poise.
Sgthoffer
West Virginia
Thank you for the advice. I will start looking.
155mm
Chief and Indian
1,246
506
Guymon, OK
Is there a mod to get the 6707 down to the 27mhz, I thought it only went as low a 30mhz. or is it just an adjusting the antenea height to get the SWR down?
dougco1
707
Cooperstown NY
As cjtroutt said, a MX-6707 works fine. I had to shorten the length of my antenna by 8"-10" and nailed the SWR on my Cobra. I also get great radio skip on partly sunny days.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
You dont Half to cut any thing use the Antenna wire and coil 3 to 5 6 inch coils in line at the base and use like choke it will help and work well also the length of the cable is a factor no less than 24 ft if you have any more questons PM me i give you my cell.
Malo7
Puyallup, WA
Will the AS-1730 antenna work also? I read your comment about the Mx-6707 and as-1739 working with a cb radio.
I purchased the Mx-6707 base but it comes with an as-1730 not an as-1739.
Any advice will be greatly appreciated. TM!
