Starter Advice
cjkeeliii
Thomasville, GA
I have just put a second passenger side alternator on my M1008. Even though the starter was not the initial problem, it is now. The GEN 2 light was on when I turned the key, but now it's out, and the starter won't turn. Also getting sparks and smoke from back battery's negative post. Any ideas? My original passenger alternator locked up and I had it rebuilt along with the driver's side alternator. Is the problem possibly in the driver's alt? Same guy rebuilt both at same time.
Westech
CPL
6,104
211
cow farts, Wisconsin
you got some wires mixed up there guy..... time to re look at what you did and make sure all the wires are correct. Also you do know that the passenger alternator HAS TO HAVE A ISOLATED GROUND. you cant use the auto parts alternator.
cjkeeliii
Thomasville, GA
I got the new(er) alternator from Parramore Surplus in Mt. Pleasant, FLA. so I'm sure its a CUCV alternator. As for the wiring: I checked another M1008 and hooked the wires up just like that one. If you're familiar with Russell Deese out of Cairo, GA., he deals in MV's. His suggestion was that I burned out the starter solenoid when I tried to crank the truck without the passenger alternator hooked up.
Ken_86gt
Williamsburg VA
? You do not need the alternators hooked up to start the vehicle. But of course no one would leave it like this for any length of time. It sounds like a wiring problem or a bad rebuild to me.
