Firejareen
- 1
- 8
- Rural Retreat VA
So I did the relay conversion no sweat. Hooked the battery back up and apparently I had a loose wire from mid-process radio install touch one of the posts on the relay. ZZZZTTT well crap. So I blew a fuze, no problem, replaced it and now the truck won't turn over. I had another relay and swapped it just to test, still not turning over. Any ideas on where I should start to look? All fuzes are good, new starter relay, batterys good. Won't turn over...Im at a loss
