starter relay mod problem
Firejareen
Rural Retreat VA
So I did the relay conversion no sweat. Hooked the battery back up and apparently I had a loose wire from mid-process radio install touch one of the posts on the relay. ZZZZTTT well crap. So I blew a fuze, no problem, replaced it and now the truck won't turn over. I had another relay and swapped it just to test, still not turning over. Any ideas on where I should start to look? All fuzes are good, new starter relay, batterys good. Won't turn over...Im at a loss
Warthog
241
OKC, OK
Did it touch the BIG post or one of the small ones?
The big post on thr relay gets it power directly from the 24v Positive Terminal Block. There is a fusible link protecting it. Check that wire.
