Static Pinion Angle Thoughts?
86m1028
17
Murphy TEXAS
Hard to say, depends on if your rears have sagged at all. The front openings are bigger than the rears so the rear would need to be slightly taller to look level
If you do decide to use a zero rate, figure out your pinion angle & buy a tapered zero rate, so your not stacking spring, zero rate & shim.
