- 10,349
- 94
- 48
- Meadows of Dan, Virginia
BASIC ISSUE and TROOP INSTALLED ITEMS
Some things are readily available, like the 5-ton snatch block (3940-105-9933) and 5/8" 16 ft chain with grab hook and pear shaped coupling (4010-473-6166).
Other things were not so easy to find, like the tire chains (2540-933-6937), which I ended up putting together from 1100-20 chains. Specifications from pictures in the TMs and specifications based on FSNs.
Configured for the Pershing 1A , the xm757 was equipped with a 10KW MEP023A 400Hz genset.
I had a MEP18A mounted on the dromedary platform for several years until the generator head failed. This is what it looked like at the time (compare vintage image).
