Steering gearbox oil level...
emmado22
147
Mid Hudson Valley NY
All,
I've checked the TM and LO, but I cant find a good answer on which fill plug the box should be filled to. #5 or #10. #5 is the bigger of the 2 fill plugs wich is the same size as the drain plug.
Any thoughts?
acetomatoco
I would suggest that the capacity is not there for three and a half pints... so... but you sure will know when you drain out the old and pour in the new... I be liking the old books...
SteveKuhn
Hasbrouck Heights NJ
After spending a half hour in the TM and LO (Emmando's right) and about as much time under the truck trying to figure this out, I finally searched SS from Google and found this old thread. Once again, the site proves valuable.
Thanks for the answers.
Steve
