Third From Texas
- 6,627
- 113
- Corpus Christi Texas
So I saved this pic for a rainy day (not my truck in top image) because I liked the concept's potential for stowage, luggage, motorcycle, etc.
I want to fab a few various decks for it depending on what I'm hauling. And I want it to "go away" so I can still pull my M1082 , car hauler, etc.
I've looked and it's a simple install really. Most everything that makes it work is visible in the pic. I may pursue a bit different roller hardware, but you get the idea.
I forget who did this (think it was an owner from HOU).
On the M1079 I will have to remove the steel plug that seals off the ladder channel from the rear (it's welded shut on the van's chassis). I'll determine if I want to retain that crossmember bolted up from below of something if needed.
