chicagodiesel
- 1
- 0
- Chicago, IL
This may sound weird, but it happened to me...a bit different of a sound, but who knows. The diaphragm started going bad on my vacuum pump and at higher rpms started squeaking like that.
Have you opened the hood and reved while listening for the sound? If it was the vac pump it would be coming from the back top of the engine. You can pull the line into the vacuum regulator on the IP while running and if you put your finger on over the hose for a second you'll be able to replicate the sound and see if that's it. But if it's shifting okay, just disregard this suggestion.
Good luck.
Good luck.
