peakbagger
- 350
- 63
- northern nh
Well the fix took about 20 minutes once I had the right snap ring pliers. After bending a few cheap snap ring pliers I ordered a screw type heavy duty version and the snap ring came off first try. I then drove the pin through the hub exposing the shaft on the other side. There was no trace of the grease hole until I took a wire brush to the shaft and then a slight divot appeared. What was in the hole wasn't that hard so I cleaned it out, cranked a bit of grease through it. and reassembled everything. Its all greased up and ready to go.
