Stuck Drag Link & Pitman Arm
ldmack3
1,740
N. Central Idaho
I didn’t see where you pulled that big straight slot plug in each end of the drag link. It shows installled in one of your pics. Cotter pin goes thru the slot. Easy to figure after you get it out. Mine were really gnarley in there but they should come right out. Bunch of pieces in there, document assembly.
Hummer Guy
819
United States Louisiana
Yea I got those off, you talking about those cotter pins at both ends of the drag link?
Hummer Guy
819
Alright, so I basically tried everything to get this off this morning. I came to conclusion, I'm going to cut it off. Where is the best spot to cut it without damaging the steering arm? I notice the steering arm seems to have some sort of ball joint holding the drag link on and then there's threads under that ball joint. Either that or where can I cut the steering arm off without damaging those 4 threads?
Hummer Guy
819
Correct. The pin then the screw in plug then the pieces. That should have freed up the ball to move to the large opening side of the keyhole allowing it to come out of the drag link.
Yea that's how it should be, I don't get how it's still stuck, from what it seems, I can cut it off at the ball stud and then drill the rest of the ball stud of the hole. At first, I thought the ball stud was possibly built into the steering arm but seems like it's a separate piece
davidb56
1,238
Bonners Ferry Idaho
put the nut back on and use a ball joint fork with a real hammer. No need to torch anything. a LITTLE heat helps, but too much will weaken the steel permanently.
