- 959
- 38
- 28
- Loxahatchee, Florida
Since I bought my M185A3 4 weeks ago, I optimistically guessed the reason it wasn't running was because it wasn't getting fuel to the injectors. After all, I "knew" this truck, why, Iv'e seen it running! But that was 5 years ago and after that it sat parked outside at the Neew York gas statuion. Here in Florida I invited a professional diesel man to help me, and after verifying fuel to the injectors, and noticing the turbo was frozen, he sprayed some vapor into the cylinders and after some cranking, ...no ignition. Now I was worried. But the compression test went like this : cylinder 6- 220 PSIG, cylinder 5- 210PSIG, cylinder 4- 180 PSIG I got more worried. Then the technician put some MARVEL MYSTERY OIL and into cylinder 4, now the compression went to 400 PSIG! What happened, I asked? Marlon said, the rings are stuck to the pistons and we got to free them or change them. So we put ounces of the mystery oil in each cylinder and hope it will work it all free. I willlso put a 50% mixture of acetone and tranny fluid.AnY other idaes?
