Super single hemmit rims hubs fliped out on rear?
11Echo
96
CT W. R.
Hey guys im getting ready to put some hemmit rims on my 5 ton but was wondering has anyone flipped the hubs out in the rear and put the hemmit's on that way? I have been looking for pics but can;t seem to find anyone that has done it. thanks kyle
A pic from the net.
blackrock
Phoenixville,Pa
hey guys went to put my hemmit rims on today and ran into this. now i know the front studs need to be longer but look at the rears. they are like a 1/2inch to short. anyone ever run into this on the rear before? thanks kyle
gringeltaube
Staff Member
2,680
Montevideo/Uruguay
blackrock
Phoenixville,Pa
Actually I ran my bud nuts up on the studs first then mounted my rim then used the larger nuts to hold the rim on mine.
if you read the threads that were refered above by gringeltaube, people don't suggest doing that cause it holds the rim from mating with the hub surface flat.
R Racing
St. Leonard, MD
It doesn't on mine . Mine had a countersink enough that it doesn't. Been running them for a few months that way and no problems.I'll have to read the other threads and see whats different with theres ?
73m819
327
gainesville, ga.
Wow, thay must have a HE!! of a countersunk hole, to get the rims FLAT,TIGHT against the hub
R Racing
St. Leonard, MD
My counter sink across the flat is .2 wide .so it is a large 1.Also if you really think about it the large tractors like my m920 are the same way in the rears . Tire than bud nut , then next tire, then big nut. They have been building trucks with the tires mounted like that for who knows how long with no issues . The Bud nuts are all cnc machined and are kept to tight tolerance.
R Racing
St. Leonard, MD
I see what your concern is. I had already machined mine down on the other beval so thats why mine doesnt sit out . I did it before i installed them so I didnt think about it anymore after the fact. It still doesnt change the fact that at least on a rear mount its a proven system.
73m819
327
gainesville, ga.
" It still doesnt change the fact that at least on a rear mount its a proven system".
yes if done as it should be, the first rim is tight against the hub, then the bud nut with the outer bevel in the countersunk hole of the first rim and the inner bevel is in the countersunk hole of the second rim and the lug nut on the out side, this set up puts both rims Tight together and tight against the hub, will not be if non moded bud nuts are used on the inside of singles, the best way is to install LONGER STUDS
blackrock
Phoenixville,Pa
does anyone have the part number for longer studs?? I just went to the truck shop and all they could find was a stud that had to be custom made by eculid, cause they dont stock them. thanks kyle
