Switch Next to Diagnostics Port
charlesrg
35
Nj
I looked over the A1 operators manual and could not find.
What's the Red switch next to the steering column. I noticed it cuts of ignition and I'm assuming it's the battery cuttoff switch as I could hear a relay click when I switched it.
Is that a battery cut off switch ? Any light on what manual I should find more info ?
Ronmar
6,623
Port angeles wa
The transmission is a small vampire load on my 12v side. Because of the rest of the configuration, 12v is the last place you want a low battery as it takes a LOT of runtime to recharge it, especially if the lights are on...
