TacticalDoc
M923 fuel preservative choice
Which is best and which do you use for fuel, oil and trans fluid?
I edited this post in light of my research regarding trans fluid in 5 tons here and speaking to others
Looked up a lot of old posts and just called 2 Allison Trans Service shops. spoke to them about the MT654CR which is not electric. Both recommended that 10w40 should be fine and they wouldn't change it to Dex3. One said Dex 3 is no longer recommended in Allison trans because it does something to the seals. and the other also did not recommend Dex 3. The difference is that the 10w40 is thicker and doesn't have the additives.
My solution is to use 10w40 for everything (steering, trans and motor... except axles) and add a preservative like lucas or Sea Foam to it. As they both said the military have been using it for years on non electronic transmissions with success and that's what I'm going to do.
So, the question is what additive do you use for your fuel and oil/trans
1. injector cleaner/fuel efficiency
2. algae/water control
3. cleaning oil deposits in the trans
What say you...
Sea Foam
Stanadyne
Diesel Kleen or Bio Kleen
StaBil
Lucas
Sea Foam
Red Line
STP
EDIT after some more research was done:::
Fuel tank;
Keep tank full to decrease water build up
Diesel Kleen with every tank full (approx. 8ml/gal) This is to clean the injectors and give you better gas mileage.
Clear Diesel (approx. 10ml/gal) Add to tank once a year to clean out sludge in your tank.
Storage of fuel;
Bio Kleen (approx.. 1ml/2gal) Add to storage tank once a year to keep fungus from growing.
PRI-D (D=diesel, approx 2ml/gal) Add to storage tank once a year to stabilize fuel. This is better than StaBil because you can treat the fuel every year for 5 years. StaBil can only be used for 1 year.
From the research I did it doesn't seem oil needs to be treated. But if you do this is what I would use
Trans and Motor;
Rotella 10w40
Add STP treatment at under 12 dollars a gallon (Lucas heavy duty oil stabilizer (10002) costs $25 per gallon). Add in a 1:5 ratio (1 gallon of STP oil treatment to 5 gal of oil
Axle and Transfer case;
80w90 gear lube
may add STP treatment at 1:5 ratio ?
What say you...
Sea Foam
Stanadyne
StaBil
Lucas
Sea Foam
Red Line
STP
Fuel tank;
Storage of fuel;
Trans and Motor;
Rotella 10w40
80w90 gear lube
