Tactical Doc's M923 fuel preservative choice
5tonman1971
Lima ohio
I called 2 Allison trans service mechanics and they said 15w40 is fine and would leave it because the trans is not electric. I'm not sure why everyone puts Dex3 in it. They said DEX3 is no longer recommended in Allison transmissions because it does something to the seals.
1 gal of motor kote is 25 bucks which is as much as lucas. STP oil treatment is just as good and costs 12 bucks per gal
I read this from of one of the reviews about Motor Kote;
This is one tremendous ripoff. I am a 30 year truck driver. I have had my Hazardous Material Certificate since it's inception. All chemicals have a data sheet for emergencies and such. I just happened to look up Motor Kote one evening while resetting hours at truck stop. It is MINERAL OIL. I repeat MOTOR KOTE IS NOTHING BUT MINERAL OIL !!! Do not believe me. Please check it out for yourself. If you want to put MINERAL OIL in your engines at least don't get screwed for $99 a gallon. You have been warned. Drive safely.
Yea I've only used motorkote a few times, I mainly use automatic transmission fluid like I said I think trans fluid is a great lube for the injectors and pump. But that is some good information and I will not use that anymore.
5tonman1971
Lima ohio
if the ATF changes the color red you may be fined for off road fuel...Just FYI
PS don't know how the title got changed to TDs preservative choice
To my knowledge from what I've seen it Dosent seem to effect the color very much at all. If for some reason a cop decides to stop an MV then I will simply show him the jug of trans fluid and explain the reasoning and pray he understands hahaha
