Tank heater
Kenneth Cole
44
Wapiti Wyoming
Hi
My question, is the 6.2 and 6.5 engine block the same. I plan on adding a block heater and have only found one called out for the 6.5.
Thanks for the help.
Ken
ken
26
Houston Texas
Yes, They are the same. In that reguard. The block heater will be the same for both.
911joeblow
72
Utah
I live up at high altitude and have cold winters. I have electric heaters on the oil pan and tranny pan, then I have a supplemental KATZ coolant heater tank/pump that circulates coolant inside the block and heads. I also have a fuel filter heater. You will never believe how easy these start when set-up this way.
