Tank salvage yard in Iraq.
EZFEED
Lafayette, LA
Tools for the fuel pump are as follows:
1 medium sized flat blade screwdriver
1 10mm box and open end wrench
Two screws at the top, two 10mm bolts at the middle. The 3 lines plumbed into the pump can be hacked off. if desired the Banjo bolts can be removed (I just recommend hacking them off) with a 19mm open end wrench. Run the screws out and drop them, loosen the 10mm bolts and they will just thumb out quickly.
I was just thinking that it might be a good idea to just bring a small crescent wrench to cover any of these or the IP's bolts and that would cover them all...the 19mm and drain plugs :?
EZFEED
Lafayette, LA
Lonesome715, I just realized that I have eaten up a good sized chunk of you topic...I am sorry about that :oops:
I'll try to keep it in PM's from now on. S'cuse me and like I said please dont trouble yourself any, if its too much or you think it ill be trouble then dont worry about it, I still appreciate the gesture! :D
Lonesome715
25
Columbus, GA
Oh man, I was looking at the fuel pump and thought that is what you were refering to. I'll see what I can do, but I a, not sure if I will be allowed to mail that out. They inspect our out going mail.
EZFEED
Lafayette, LA
Sure j'es lemme know and tag on a price for your trouble too! :)
The little pump should be a mailable item too. Its pretty small, not much bigger than a camera or bar of soap.
EZFEED
Lafayette, LA
If you find one then you decide, if you think you can thats cool, if not thats cool too, whatever is easy for you! :D
You are right though, it is a little too bulky.
EZFEED
Lafayette, LA
Be careful and watch out for snakes!!!!! :shock:
I've had allot of close calls with rattlers and copperheads while hunting for parts, seems they especially love to lie around in tires :?
Lonesome715
25
Columbus, GA
Here are some more. I just made a trip out there. There are more vehicles in another location. But I do have a job to do, so I will get to those at another time.
Lonesome715
25
Columbus, GA
The sun makes taking good photographs very tough. I had to delete several when I got back to my office.
Lonesome715
25
Columbus, GA
By the way. I found a IP on the ground that was near one of the Russian vehicles. I took a photograph but it did not come out. I will be returing with my labor crew so I can have them collect all those new washers on the ground. (my wife hates it when I send stuff home) While I am there I will get another photograph of it.
kcimb
212
Fort Worth, Texas
It's like candyland out their with mines.
I'd steer clear of the vehicles that look like they have holes in them. M1a2 DU ammo..depleted uranium :-0
