Barrman
- 1,725
- 113
- Giddings, Texas
The front drive shaft was in the back seat when I picked up the M1009. The caps were gone from the u-joint as well. I figured it had a bad u-joint and whatever agency had it just didn't fix it. I checked out the pinion yoke and it moved and felt fine. Dirt packed into the threads, but that shouldn't be a problem.
I collected the proper u-joint, tie down straps and bolts. I crawled under the truck and used a pick to get most of the crud out. Some of it wouldn't even move out with a pick. Penetrating oil and lube were sprayed in and a tap was run through to make the threads work.
All went well getting the threads clean on the first pair of holes. I was running the tap in on the third when it snapped off. Off comes the yoke.
I have tried heat, little punches, drilling, big punches, just about any combination of things to get the tap out and no luck. Anybody have any suggestions?
I think there are actually two broken off taps in there. Because the distance taken up is longer than my tap was and the one all the way in looks dirty while mine was clean. That means I have a pair basically jammed together or "lock nutted" together. At least I know why they didn't fix it before.
