BFR
Rocket Surgeon
- 2,330
- 42
- 48
- North Georgia
does anyone have any recomendations for what bit & tap to use on the exhaust manifold when installing the probe for a pyro?
jimk said:"We might mention that some mechanics fear installing the pyrometer thermocouple in the exhaust manifold for fear the probe will break or burn off and blow into the turbocharger.....While the above scenario is scary, it is also unlikely....It just doesn’t happen with a good pyrometer."
Only seen this twice in a 25+ year + career. When it happens, it's expensive
Thanks,Will, I was wondering what you had to say. 2 seems like a lot. Do you remember any details? Excessive EGT damage the probe? Cheap probe? Metal fatique?If it was the former, and the probe got too hot, the gauge should have indicated it. Perhaps the driver is to blame???Will wrote:
Pre-T probe in a divided exhaust manifold means info on just half the engine. A post-T probe may be less 'accurate' but may be a more 'reliable' indication of overall engine EGT. It also eliminates the risk of turbine damage, however low that may be.Banks wrote:
"This variance is why installation of the thermocouple in the exhaust manifold is considered more accurate. "
