- 8,697
- 3,141
- 113
- Monrovia, Ca.
Stinger (a) The thing the geor into the exhaus gas flow.
Stinger (b) On a Cummins any way...There is a 1/8 NPT plug at the back of the governer housing on a PT..Pressure Timed..fuel pump. That plug is directly in back of the governer spring pack...the part of the pump that limits high end RPM. If you were to add..by drilling and inserting, or by welding, a piece of welding rod, or similar, 1 1/2 inches long, onto/into that plug. You can effectivly remove the governer on a PT fuel pump, ie, unlimited RPM.
The 855 will handle sustained RPM of up to 3000 RPM, and last, with one driver who has learned how to drive it. But, the L10 don't like that kind of RPM. They like to come apart at around 2800 sustained RPM
