New Tatra 813 owner in Sweden
Yeah it fits fine, it's about 30 cm longer (because of the added turbos) but otherwise fits without many problems. Even fits under the original covers, its only 7 cm higher and not wider. Had to move the engine supports around and extended the doghouse a bit, that's basically it. Little low on leg-room on the rear bench, have to find a solution for that still.Did you have enough room for the new engine, it really looks a lot bigger.
i had a 813 kolos and dreamed of the turbo set up like what you have. It makes a big difference.Yeah The old engine needed a full rebuild, and I figured when I had it out of the truck I might as well put another. But once you go V12 you cannot go back (especially not without your friends mocking you), so I bought a bigger v12 instead
On the left the original Tatra T930 engine (V12, 17.6 liter) from the T813, to the right the new Tatra T3-930 engine (V12 19 liter bi-turbo) of a T815 that when in.
